Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Axle Upgrade/Minimum Scrub Radius
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Hooked JJ151's Avatar
    Aug 2018
    Oregon
    107
    Installed brand be Dynatrac XD60s a couple weeks ago and cant seem to figure out why I have death wobble above 45mph. Installed new MetalCloak adjustable control arms and trac bar on AEV 4.5 coil springs. New wheels are Hutchinson beadlocks with 5.28 of backspace. Based on videos Ive seen from Dynatrac and on this forum it seems that this combination creates a very tight scrub radius. In my case its about 0.5. The alignment shop is now telling me after my second alignment adjusting caster from 6 degrees to 7.5 degrees that I should only have a backspace of 3.5-4 My question is does or can having a smaller near zero scrub radius cause death wobble?
  2. #2
    Meme King WJCO's Avatar
    Sep 2015
    Colorado
    27,349
    Something has to be loose somewhere for death wobble to occur. Double check that all bolts are torqued properly and no parts have play.
  3. #3
    Oct 2012
    SoCal
    30,210
    Quote Originally Posted by JJ151 View Post
    So the increased caster and told you to get wheels with less backspacing? Sounds to me like that shop really knows what they are doing. Maybe have them work on a Barbie hot wheels instead.
    2012 Dozer JK
    -Dynatrac PR44/Rubicon Rear
    -Nitto 37 Trail Grapplers
    -Rock Krawler 2.5 Lift
    -ATX Slabs
    -Warn VR8
    -EVO Armor/Bumpers
    2012 Billet Silver JKUR
    -EVO DTD front and rear
    -Dynatrac PR60/PR80
    -EVO High Clearance Long Arm
    -Nitto 40 Trail grapplers
    -KMC Machetes
    -Warn CTI 9.5
    -EVO Armor/Bumpers
    1975 DJ5
  4. #4
  5. #5
    Aug 2018
    Oregon
    107
    Awesome link! Thanks!!
  6. #6
    Oct 2011
    Carson City, NV
    51,990
    WTF? Ummm, I think you need to find yourself a new shop. MORE back spacing is what you want and near zero scrub radius is AWESOME and desired. Not only will it make turning easier and better, it'll also help protect things like your ball joints and help keep them and your wheel bearings from wearing out prematurely.
    Death wobble is caused by loose or worn out steering and/or suspension components - PERIOD. If everything is new on your Jeep, you most likely have a bolt or two that isn't tightened to torque spec. If everything is, the quality of your components probably suck and they're allowing for too much movement in the bushings or are flexing. You should NOT need anything more than factory caster and that's 4. If you have 6, that should be awesome and no more is needed.
  7. #7
    Hooked Braxtonsag's Avatar
    Jan 2018
    Central Indiana
    229
    Are you sure its death wobble and not bump steer?
  8. #8
    Aug 2018
    Oregon
    107
    Quote Originally Posted by Braxtonsag View Post
    Certain its death wobble. Have to come to almost a complete stop to get it to stop oscillating.
  9. #9
    Aug 2018
    Oregon
    107
    Thats what I thought. Dynatrac says 6 degrees too.
  10. #10
    Aug 2018
    Oregon
    107
    Here are 4 pics of the front upper control arms. The first 2 are the passenger and the second two are the drivers side. Both sets are on the axle. It looks like there arm sleeve isnt seated properly? Im not a mechanic so am not sure. For those of you that do installs, whats your opinion?
Similar Threads
  1. Replies: 61
    Last Post: 03-22-2017, 11:54 PM
  2. What's the minimum backspacing for ProRock 60 Axle?
    By LarryG in forum Jeep JK Wrangler
    Last Post: 09-06-2016, 08:40 PM
  3. Axle upgrade
    By TJ KID in forum Jeep Show & Tell
    Last Post: 01-19-2014, 12:40 AM
  4. Axle Upgrade
    By 94YJBeaver in forum Jeep TJ & YJ Wrangler
    Last Post: 02-23-2013, 10:35 PM
wayoflife is a moniker that Ive been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
