Page 2 of 14 FirstFirst 123412 ... LastLast
Results 11 to 20 of 135
Thread: Motech LS Swap Gremlins
  1. #11
    Fresh Catch
    Sep 2018
    Mexico
    20
    What radiator are you using?
  2. #12
    Knows a Thing or Two Bierpower's Avatar
    Sep 2014
    Colorado Springs
    920
    That must be a newer Jeep thing because I pulled the old pedal out of my 07 and have had zero negative effects.
    Quote Originally Posted by Sharkey View Post
    I actually didn't know the gas pedal was cut and a new one was placed next to it. I know it sounds stupid, but I am waaaaay to OCD for that shit. Seriously, that is the kind of detail that would make me go with a Hemi even if it weighed more and didn't have as much aftermarket support.
  3. #13
    Nothing but a Thing RockinAZJK's Avatar
    May 2016
    Waco, Texas
    1,422
    I agree. Donít know if I that route is really in the cards for me, but I certainly couldnít do all of that if the stock pedal is a stub under there. Lol
  4. #14
    Advertiser Exodus 4x4's Avatar
    Feb 2015
    Texas
    3,493
    Quote Originally Posted by Bierpower View Post
    Quote Originally Posted by RockinAZJK View Post
    Itís not necessary to keep it in. Iíve pulled it and only plug it back in when the oil change needs to be reset.
  5. #15
    Addict jesse3638's Avatar
    Sep 2012
    Apple Valley, CA
    6,196
    Quote Originally Posted by Exodus Jeeps View Post
    You'd figure a programmer could reset that vs. plugging the pedal back in.
  6. #16
    Been Around the Block SLO's Avatar
    Jul 2016
    Portland, OR
    340
    What Bubba said ^^^^ Your winch is blocking too much of your grill. I know it'd be a pain but remove it just for a test and you'll see that you get lower numbers.
    Yeah I would get a bumper thatíll allow the winch to sit lower. I program the fans here to run at 40% at 203-206 because we have decent humidity and temps in the summer are normally around 100. Itís nearly impossible to control the engine temperature in that type of environment without turning up the fan. Try adding Water Wetter or an equivalent. They have it at Autozone. It MIGHT help.
    Sounds like Iíll be ordering the PS Bruiser bumper. I was hoping not to have to re-do the front end but whatever it takes at this point.
    I finally got a hold of Robbie today (about 20 seconds before driving the damn thing off a cliff). He thinks there may be an air bubble in the radiator which is very possible. The first run I did when I got it back, I overheated and it spit coolant everywhere. I never filled it back to the point of bubbling over while the engine is running and then filling the bottle (which apparently is very important). Iím going to give that a try in the morning.
    I do think the t-stat could be bad as well.
    Last thing Iím going to try is an updated tune from John at Overland. Just had someone overnight my auto cal tuner and laptop to Moab. The only thing I forgot to bring.
  7. #17
    Been Around the Block uberc4's Avatar
    Aug 2015
    Arizona
    479
    Sorry to hear about your issues. Hopefully they can get ironed out! Given the troubles you have had would you still recommend them for a V8 swap? It appears that their customer support is top notch.
  8. #18
    Feb 2015
    Texas
    3,493
    Quote Originally Posted by SLO View Post
    Yep, never leave for a trip without your programming tools! Iíve mad adjustments to mine while on Imogene Pass. Didnít work because the shitty Pentastar fan shit the bed but at least I had the capability.
    The thermostat is an easy fix on the truck motors. If you want to be sure theres no air in the system, pull the steam line off the radiator and hold it up while someone else fills the radiator. This allows air BEHIND the thermostat to get all the way out. Youíll also need to hold your finger over the hole on the radiator where you pulled the steam line off. Also be sure to push down on the upper radiator hose after this step. It tends to sit higher than the fill neck of the radiator and trap air.
  9. #19
    Nothing but a Thing jorgelrod's Avatar
    Sep 2013
    Jacksonville, FL
    2,002
    I am kind of on the same boat on this one, it's just that 8L90 that keeps me on the fence on this when the time comes.
  10. #20
    Jul 2016
    Portland, OR
    340
    I actually didn't know the gas pedal was cut and a new one was placed next to it. I know it sounds stupid, but I am waaaaay too OCD for that shit. Seriously, that is the kind of detail that would make me go with a Hemi even if it weighed more and didn't have as much aftermarket support.
    Quote Originally Posted by jorgelrod View Post
    Iím super anal about things like that but having the cut pedal didnít bother me one bit.
    I do wish, however, that i would have gone with a Gen V with the 8L90. That engine is just a whole other level and the 8-speed transmission would be REALLY nice. We have a 2016 Escalade with the Gen V LT and 8L90 and I just bought my wife a JL. 8 speed is where itís at. Makes the 6L80 and Gen IV seem so antiquated.
Similar Threads
  1. Motech Swap
    By Rocralr in forum Jeep JK Wrangler
    Last Post: 06-21-2018, 12:17 AM
  2. Replies: 35
    Last Post: 05-03-2017, 01:20 PM
  3. It's Time to SUPERSIZE Moby - MoTech 6.2L LS Jeep Motor Swap
    By CarsonCindy in forum Member Jeep Builds
    Last Post: 09-28-2016, 03:37 PM
  4. CB Gremlins
    By Slimebones in forum Jeep JK Wrangler
    Last Post: 04-24-2016, 11:59 PM
  5. Replies: 10
    Last Post: 09-18-2015, 05:17 PM
