Page 1 of 20 12311 ... LastLast
Results 1 to 10 of 193
Thread: Steering wheel wobble sometimes full on death wobble 19 JLUR
  1. #1
    Old Timer bkac's Avatar
    Join Date
    Dec 2012
    Location
    Center of Oregon
    Posts
    3,858
    Iím really at a loss and looking for something. I have a 19 JLUR and Iíve been fighting a steering wheel shimmy to full on death wobble. It only happens at slow speeds when hitting a bump with just one tire or both when itís not dead on the bump. Iíd say up to 35 mph. It requires me to slow to about 5-10 mph to get it to stop and mainly only happens when itís cold. Hereís what Iíve done so far to defeat this really annoying issue. Itís been happening for months now off and on. Iíve tightened the balljoints, replaced the draglink, tierod, Trackbar, power steering pump, steering box, checked wheel bearings, control arms, checked alignment caster 6.6 6.8 degrees toe is set in 1/8Ē, tires are balanced. The whee is smooth until it starts. I have done the stabilizer recall twice, AD then AE part numbers. This one is so frustrating because everything is tight on the jeep. The lift has 10k miles on it. Iím at 4Ē of lift. It all just started one day around 9k miles on the jeep. Before that it was solid all the time. Does anyone have any ideas? Iím honestly at a loss now. Iím wondering if the frame is actually flexing and causing it. The frame is so much thinner on a JL then a JK. Iím at this point just guessing but would love some ideas or input. I might try an aftermarket stabilizer and the synergy Trackbar brace next but at this point Iím just throwing money at a problem.
    Not "living" but "loving" life always!
  2. #2
    Meme King WJCO's Avatar
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    29,187
    Quote Originally Posted by bkac View Post
    Sounds like exactly what's going on with Doubletapdaddy's. He's checked everything and is really frustrated about it for sure. : https://jlwrangler.com/showthread.ph...ll=1#post54979
    What lift are you running?
    Jeep JT GLADIATOR FORUM: www.JT-Gladiator.com
  3. #3
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,015
    Honestly, it's everyone. Mel has it, Doubletapdaddy has it, you have it and now that it's been getting really cold out, we seem to have it again too. I just picked up a Synergy track bar frame mount brace to see if that'll help things out.
  4. #4
    Addict Ddays's Avatar
    Join Date
    Aug 2015
    Location
    Darlington, Pa
    Posts
    9,925
    Isn't this the one for sale?
    https://wayalife.com/showthread.php/...build-of-Gruff
    Gruff 2014 JKU Moneypit
    Badger 2019 JLUR waiting for scraps
  5. #5
    Join Date
    Sep 2015
    Location
    Colorado
    Posts
    29,187
    As far as you and Mel, On the JL or JT ?
  6. #6
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,015
    Quote Originally Posted by WJCO View Post
    On the JL. I thought I had licked this problem but yesterday, I took my JL out to run some errands and had DW. Granted, it's the first time the temps have been down in the 30's in quite some time. Not sure why cold seems to make such a difference but it does. I've been hearing from lots of JL owners who have the same problem too.
  7. #7
    Join Date
    Oct 2011
    Location
    Carson City, NV
    Posts
    54,015
    I should note that I am no longer running the Rancho track bar. Also, I did find that the OE stabilizer did a much better job at dampening than the new Fox one I have now. Just throwing that out there for data.
  8. #8
    Join Date
    Dec 2012
    Location
    Center of Oregon
    Posts
    3,858
    Quote Originally Posted by Ddays View Post
    Yes Iím selling it, I thought I had it fixed with the new steering box but it happened again yesterday. Thatís another reason Iím trying to get to the bottom of it. It just started getting cold again and itís now happening more often.
  9. #9
    Join Date
    Dec 2012
    Location
    Center of Oregon
    Posts
    3,858
    I grabbed a new style OEM Trackbar last week and swapped it to see if it made a difference from my RK one that everything is tight on. Whatís odd is if you pull the stabilizer and move it by hand it has a bit of movement before it gets tight almost like thereís air. Durham mentioned taking a steering ram and coupling the two ports together and bleed the air out. He said it makes a solid stabilizer. But we all know itís just masking the real issue.
  10. #10
    Join Date
    Dec 2012
    Location
    Center of Oregon
    Posts
    3,858
    I have a 3.5Ē RK with 3/4Ē daystar isolators. All new control arms and trackbars. Iíve had someone tell me that the drop brackets really help with this issue and also going longarm. Iím down for trying anything but donít want to keep throwing wasted money and no fixes. I was told the arms really like being flat on the JL idk just grasping for answers.
Similar Threads
  1. Death wobble after tire/wheel swap
    By clark98ut in forum Jeep JK Wrangler
    Last Post: 12-21-2017, 05:08 PM
  2. Death Wobble - Caused by Steering Box?
    By Benito in forum Jeep JK Wrangler
    Last Post: 12-21-2017, 03:43 PM
  3. Death Wobble Help
    By BlackJKU08 in forum Jeep JK Wrangler
    Last Post: 05-30-2017, 03:19 PM
  4. Steering wheel wobble
    By glassboy in forum Jeep JK Wrangler
    Last Post: 03-25-2016, 09:03 PM
  5. Steering wheel vibration? Not death wobble
    By bl17z90 in forum Jeep JK Wrangler
    Last Post: 11-02-2013, 04:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
About us
ďwayoflifeĒ is a moniker that Iíve been using for 20 years now and I chose it because I think it does a great job of explaining, in simple terms, the passion I have for Jeeps and the Jeep way of life. This is a lifestyle that transcends age, gender and race as the only thing you need to be a part of it is a love for the outdoors, a desire to explore, a yearning to take on a challenge and a will to conquer it. Over the years, Cindy and I have attempted to capture the essence of this lifestyle through photographs and videos and share it with others around the world. And, this is how WAYALIFE was born.
Join us
WATCH OUR VIDEOS
