I have done everything you can imagine to stop this.
I am giving up. :thinking:
Lol. Welcome to WAL. You just venting or want some help? Gonna need more info.
Pressurized steering stabilizer by any chance?
Do you have an alignment print out to share? What kind of tires are you running? Have you rotated front tires side to side to see if pull changes direction?
Some tires have a slight pull. I used to have nittos that pulled left.
Sent from my iPhone using WAYALIFE mobile app[/QUOTE
It changes lanes on the road quick
Bad alignment, bad tires, incorrect tire pressure, Nitto Trail Grapplers, bad ball joints, bad rod ends in the steering linkages, too fucking windy... I dunno, what have you done so far? [emoji849]Yes I do have one. A bilstein. I toke it off and It made no difference. I also put a JL factory and still pulls......
What do you think it is?
Caster off? Do you have a lift? Fuck man, give us more info, otherwise we're just throwing darts here.Some tires have a slight pull. I used to have nittos that pulled left.
I run 30 psi. All my steering components are new. I am very picky. I have new adjustable synergy arms. Teraflex track bar. The axle is centered perfect! Tires are new. Nothing is worn outBad alignment, bad tires, incorrect tire pressure, Nitto Trail Grapplers, bad ball joints, bad rod ends in the steering linkages, too fucking windy... I dunno, what have you done so far? [emoji849]
Alright... So as asked above, have you had it on an alignment rack and gotten a printout? Pulling and flighty steering sounds like it might be a caster issue. You triple-checked the torque on all the suspension components?I run 30 psi. All my steering components are new. I am very picky. I have new adjustable synergy arms. Teraflex track bar. The axle is centered perfect! Tires are new. Nothing is worn out
Caster is 5 degrees both sides. 3 inch lift. Synergy springs. All arms are equal lengths side to side. Toe is 0.10°.
Is this a drift or a pull?
