Very nice. What stretch kit did you go with? I see that synergy and rock krawler has kits.
Sent from my BNTV600 using WAYALIFE mobile app
Love me a nice and low stretched 2 door. Look forward to seeing it finished. :thumb:
I would not want to run a truss on either axles, being the axles are already so heavy and should not need the reinforcement in the first place. Just my opinion
i would agree, but i had it, so it got used
I don't blame you at all. And even if that is what you wanted to do I'm not knocking it. I think it's awesome your building you rig. I go back and forth on building or buying.
Like WJCO said, its more for bracket placement. The truss isn't needed, but that's just how Artec makes the kit. It just makes it easier to swap in. You can always get mounts that don't require a truss, but that adds more time to the build because you have to measure on the axle where you want the brackets to go, which is what you'll see with more custom suspensions. The Artec kit takes all that work out because the brackets attach to their truss at certain spots, making it bolt up just like the stock 44 would.So I've noticed that a lot of the guys that do the Sterling axle swaps tend to add the trusses. In fact, I don't think I've ever seen one done that isn't trussed.
Is there a reason for that? I mean, you're going to one ton axles in a relatively light weight vehicle. Do the sterling axles tend to bend or break?
After seeing some of your builds Iam exited to see what you do to your 2 Dr
Glad to see you made a build thread, and awesome you are using the stock control arm mounts. Badass truck builds, cool to see someone else on here come from the lowered side of things which is where I came from originally.
