Bought my JKUR in March, 2013. Threw this code on a paved uphill at 45 mph...the tach rose to somewhere between 3500 and 5500 and it cut the throttle and the engine light came on. I lifted off the throttle and after 2 seconds or so, power returned and I was able to continue up the hill at about 25 mph or so. The check engine light stayed on for a few days afterward, but the jeep drove normally. It showed me this code in the odometer when I did the "twist the key 3 times" dance. Dealership said the oil level was fine (btw they just changed the oil a few weeks prior) and claimed that they fixed the issue with a "software upgrade". 6 weeks later, on a similar uphill climb at around 45 mph, it occurred again. The check engine light stayed on for two days, but it would not give me any code in the odometer. Oil level was fine. A day later the light cleared. Two days later, on a straightaway at around 45 mph, while accelerating, it happened again. This time, the Jeep would not let me accelerate at all (it continued decelerating) until I manually shifted (Mine is a 5-speed automatic) into 3rd gear, then it began to accelerate, then i manually shifted to 4th, then i continued driving. It gave me no code in the odometer. Oil level was fine. A day later the light cleared. Taking it to the dealership again in 4 days.
Can anyone help? Has anyone experienced this behavior in a 2013 and found the cause or solution??
Thanks-
