MedixJK
I forgot about that...ill dig around for it.I think someone asked Eddie about it because he runs them on Rubicat and he doesn't think it's that bad. You might look for that. Bearings assemblies are cheap anyways.
I saw that. Must be a supply and demand thing.Not to mention if you go with the STT pros, the 13.5's are 10 ply versus 8 for the 12.5's. And cheaper too.
I may be off base but I think you have backspace and offset confused or I'm not understanding this. Backspace is backspace regardless of wheel width.
Medix, I went round and round between wheels and tires before I finally just sprung for Slabs due to the rubbing issues. From all the reading I've done on it it seems two identical jeeps could run the same setup and one rubs and one does not. I went the 12.5 route on tires strictly due to rating. I believe the 13.5 TG was E rated while 12.5 was D. I thought the D would have a little more sidewall flex. With my tire and wheel combo I'm pretty sure I would have rubbing issues with less than (or more than depending on how you look at it) backspace even with the 12.5. I know that probably doesn't help your decision, just giving you my take on it.
RT231 Raceline Monsters 17x9.5 -32mm offset and 4 bs or XD229 Machete BLs 17x9 -38mm offset and 3.5 bs and running 37/13.5's on them ... Anyone running either?
4" Enforcer Kit (to be installed prior)
What do you guys think? Rubbing issues?
Im getting rub against my lca's at full turn now. 37x12.50 on 4.5BS. Glad i didnt go 13.50. You think adding spacers would make my BS too low?If you're gonna run 13.50's, I would recommend 3.5" of back spacing to help prevent rubbing. At 4", you will most likely see rubbing at a full flex and turn.
I couldnt find a convo about this anywhere so id like to hear your thoughts, opinions and reasoning as to why you would prefer one over the other.
Edit: let me add that they would probably be going on a non-beadlock wheel with a width of 8.5-9". BS on those wheels looks to run between 4.25-4.5".
