ERAUGrad04
That's definitely true. It's not the whole picture, but the chart is a great place to start and does get very close. The chart doesn't reference tire pressures either, which will also change your rolling resistance. That being said, if your running 3000 rpm at 60 mph with 37s and 5.13 gears in a 3.6L, something is seriously wrong.
Is there really enough difference in mass between the different selection of 37" tires and different wheel combos to change the rolling RPM at 70mph by some huge margin? I would think it would only change within some small percentage. I'm not a tire and wheel mass expert but I did stay at a Holiday Inn Express on more than one occasion.![]()
Staying at a Holiday Inn Express is always worth something! :thumb:
You'd be surprised at the weight of some of these tire/wheel combos. For example, a 37" Nitto Trail Grappler weighs in at 84lbs while a BFG MT is 71lbs. In tire weight, that is 13lbs or 18% heavier. For wheel comparison, an AEV Pinter weighs 27lbs compared to a Slab at 34lbs.
If you swing to the extremes here, a Nitto mounted to the Slab weights 118lbs while the BFG/Pintler combo is 98lbs. That's a difference of 20lbs and nearly 21%.
Not only does your powertrain have to overcome the loss of mechanical advantage of the 37" tire, it also has to get it moving. If you were to mount both of these tire/wheel combos to a low resistance spindle (kinda like a Price-is-Right wheel!) side by side and give each one a spin, that extra 20lbs would be quite noticeable and would require a bit more umph to get going.
