68' M715 AKA "Smokey", 8.1 engine on links, coils and 40's
Rock40
Playing around with the front tires and steering angles/clearance. Trying to figure out what wheel backspacing to use. Wheels will eventually be TrailReady beadlocks
Dirty passenger side axle tube...
Clean tube, ready for links
The passenger side link also incorporates the panhard bar mount
Rock40
Here's the upper panhard bar mount. Probably not in it's final location front and back but close. Probably.
Panhard around the front differential. It'll need a little bend in it for sure in order to clear. Definitely will need a short pitman arm in the long run too
And here is less than 9" of link material waste which represents nearly $30. Goodness the stuff is expensive
Rock40
Got the rear link tubing and then tacked things together. No more PVC test links!
Here's a shot of test fitting the front fender. The frame of the truck is set to represent 2" of total lift over stock. I'm hoping for no more, but maybe less than this.
Rock40
Working on the front upper links here. Two large “nutserts” are frenched into the frame and welded to the bracket. Custom made and tapped to 5/8-18 they have about 1” of thread engagement and allows the bracket to suck all the way up against the frame maximizing tire to link clearance
The link bracket also incorporates the front body mount seen here
Rock40
Pic of the frame notch needed for the threaded nutsert
Nutsert welded to link bracket
Cycling the suspension. It's works, and should work quite well
wjtstudios
First off, Welcome to the forum!
This is unbelievable project, the design and skills it’s taken to create this build are insane!!
And great job Documenting everything, it’s awesome following along with the build.
Try not to reference other forums or platforms out of respect for Eddie and what he’s created here. If you can, delete that reference from you first post
Again, awesome project, keep the pictures coming!! Can’t wait to see what this beast can do in the trail
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Rock40
2015 JKUR AEV JK350
1985 CJ8 Scrambler
Done. Sorry about that, never even occurred to me. Thanks for checking out the build!
KevinG
Welcome from just a little north of you! So much fun scrolling through the work. Amazing job. Cant wait to see more! :thumb:
Rock40
OK....Many thanks to TrailReady that loaned out this mockup wheel so I could really dial in the backspacing. It’s cracked clean through from racing KOH but it did the trick
Definitely assisted with finding the right backspacing. But.... unfortunately it's going to require some serious changes to our original plan. We were planning on running the factory Dana Dually hubs to match the Dana 70HD but it won't work. For those that aren't super familiar with M715's, they are VERY wide from the factory so it's hard to match the factory axle width with an axle swap.
So, we're ditching the D60 dually hubs altogether and going with SRW hubs and wheels with 3.5" of backspacing. It'll allow full steering lock to lock and with 2" of suspension lift, essentially no sheet metal trimming to run the 40's. As an added benefit, this thing might actually fit down some NW wheeling trails.
Wheels are on order so I moved on to trimming the rear frame down. In total, shortened it 22.25" as I wanted the truck to have extremely good breakover angles
I do not love cutting frames but if you're going to do it, do it right and take your time
Rock40
Braced the fame pretty heavily forward of the cuts to prevent any movement or warping
Cut at a 45 degree angle and cleaned up
Welded, will be plated later also
And here's a tire mock-up, much shorter, which we like :)
Rock40
Maybe it’s just me but I had a heck of a time finding a GM 14B locally. I probably visited 4-5 different yards before finding this one from a 79' 2WD. Got it hub to hub, no warranty for $189 which is just fine with me since I really only want the housing anyway. When I told the nice junkyard man I was only after the housing he looked at me like I was nuts, oh well.
Tore it down fully, had 3.73 gears and was super clean inside. Brakes looked more or less fresh. Threw all that nonsense in the recycling pile
Back from the blaster and ready for some fab. I just can't stand working on dirty parts and for $75 in blasting? Well worth it
Rock40
I’m beginning to square away interior bits also. This is a Vintage Air Magnum unit. Both heat and AC. It's gigantic and it JUST fit against the firewall. For those with "J" trucks, this unit will "probably" fit also and it's supposed to REALLY put out the head and AC
Tucked right above the passenger side footwell
And just clears the firewall hump where the defrost and heat ducts exit the unit
Rock40
These are the Vintage Air vents. They fit quite well over the factory M715 vent ports but need to be custom mounted
The goal on this build is to use nutserts or welded studs whenever possible. They make assembly/disassembly very easy since you don't need a backup wrench. These studs are TIG welded in place and I'll just sand this smooth prior to paint
Rock40
Old factory dash/gauge cluster. And yeah, the miles are original
New and updated gauges
This is the factory M715 complete frame and engine harness. Overall, not terrible but not great shape either. I sorted it all out and separated the bits used just to control the large factory dimmer/military lights/headlight switch
I want to retain this switch as there is a large hole in the dash already for it and it's totally original. It will control the headlights/taillights eventually
Rock40
On to retrofitting the pedals. Fortunately the GM pedal that mates to the 8.1 is drive by wire since threading a throttle cable would be essentially impossible. The clutch and brake pedals are factory on the factory hangers. All three align quite well
Before the pedals can be finalized, I needed to repair and reinforce essentially the entire driver side firewall. It's pockmocked with all kinds of holes and this is not the result of me :( I'm lucky that my next door neighbor owns a fabrication business and he supplied a small pile of 14g sheet metal for the firewall
Here's the factory firewall, pretty much a mess. There's a 14g reinforcement plate already in place which I considered removing and decided against. Too much work and too many spot welds. The round hole is one of the factory fresh air inlets
New 14g plate going in to level things out...
TIG'd in place. I used silicon bronze against the outermost edge, ER70S2 for everything else.
Rock40
Fully welding the top of the factory plate and blending the two together...
Final plate going in which will tie the entire firewall together and provide a completely flat mounting surface
Done and Hydroboost until mounted
A few more plating bits to help seal everything up
Rock40
Transitioned to the inner firewall in the driver footwell. I needed to plate this also so that I could properly mount the Flaming River steering column support. It requires a flat surface and I wanted to seal up the firewall very well.
This is where the steering column support will eventually go
Rock40
Prepping to cut the hole for the new Wilwood clutch master cylinder. The truck was originally a goofy mechanical pushrod system for the clutch. At the very least, I triple checked this against where the clutch pedal was located before cutting the hole
Done, the Wilwood until is super clean and simple. It has a 3/4" bore
In conjunction with the Hydroboost and there's quite a bit of room to the right of the clutch master cylinder to mount other stuff
Moved on to making some required changes to the pedals since this obviously was never equipped with hydroboost or a hydraulic clutch. To my surprise, I found that the clutch pedal actually pivots on needle bearings. Fancy. What you're seeing here is completely solidified grease circa Vietnam War
Clutch pedal. The bracket was for the original rod linkage. I drilled it out and popped it off. I added the 3rd hole in the middle, that's right where the Wilwood master cylinder rod wants to go. Drilled 5/16" and I'll make a custom clevis for it
