Sheaffadelic
I want to replace the normal zerk fittings on the Evo LCAs to a 90 degree fitting so I do not have to drop the arms to grease... Question is anyone know what size the insert is?... Thanks in advance!
Just called evo, nick already knows but just for everyones information, they are 1/4-28
Thanks a ton. Ive been meaning to change mine as well.Just called evo, nick already knows but just for everyones information, they are 1/4-28
**mental note, I need to do this soon**
Side note, cant we just take our used oil and dump it all over the suspension and driveline to lube it up? Head it helps cure break squeal also!
While on the topic, what Grease/Gun is everyone using?
Did you do 90* zerks? I posted in my thread earlier but didnt get much feed back....i tried putting 90* zerks in but they tighten up facing almost perfectly sideways. I know people have done it, so whats the solution? LolSorry, don't remember the exact size but you can always just pull one off and take it to the store with you to size it up. :yup:
