JK_Dave
You should put the pinion yokes on with a rotational torque wrench
It should be clarified that he won't install the new pinion yoke with this thing. He needs a proper torque wrench for that. The wrench pictured simply measures the amount of torque that's on the existing pinion nut in order to determine the amount of torque currently applied to the crush sleeve inside the diff. When he goes to install the new yoke, he'll want to add 5ft-lbs to the new pinion nut so that the crush sleeve is still applying force back against the nut.
But, he should really read or know about this anyway before he installs the new d/s.
