Thanks guys for all of the input. I have decided on going with a sPOD and an ARB twin air compressor under the hood. What are some mounts that you guys use (i.e. a dual mount or two different mounts that will both fit). Also I am considering buying the plug and play adapter for the compressor to the sPOD. I know a lot of you guys disagree with the sPOD company name and company all around but I am deciding to go this route due to the simplicity of the install, the factory finish look, and so I can have 6 flip switches.
Thanks guys!
Anyone run the sPOD and a twin ARB air compressor under the hood?
The owner of sPod is a dick! Last year I tried talking with him regarding his product at the offroad expo and he was rude as fuck. I went with a Switch-Pros and couldn't be happier! Their customer service is fantastic! I can't say enough great things about them seriously. That said I'm running the Switch-Pros and ARB twin compressor mounted on a Metalcloak under hood mount. The switch panel I located in front of the shift lever using a Daystar lower dash mount. It turned out great! I would seriously look into Switch-Pros, they offer so much more for less money than sPod.
As mentioned, I caught sPOD red handed trying to undercover pimp by trying to be a regular member. The proof of it can be found here:
http://wayalife.com/showthread.php?15125-sPOD-Honesty-Integrity-and-the-Lack-Thereof
I know there are many in this country who no longer care about things like honesty and integrity but I still care about them. If you don't care and really want to buy their product in spite of what they've been caught doing, don't let me stand in your way.
So back to lighting, what do you guys use for back up lighting? I was thinking using the mounts that screw on the top of the tail lights and then throwing on Rigid Industries SR-Q Diffused 60 Degree pattern. Does anyone run these specific lights? I'm trying to decide if these or just floods would be better? Thanks guys!
Okay so after some thought I will put my "looks" preference aside and check into the Switch Pro system. Could you guys post some pics of places where you installed the switch panel. Also a possible overview of install/ what I'll need to do it.
Thanks guys!
Thanks guys!
I like that mountingSuper easy install, great tech support, and an all around awesome product.
I mounted mine above the rear view mirror and ran the wiring in the trim. View attachment 227975
Thanks guys!
I like that install, is the mount pretty sturdy/ interfere at all with the loop for the harp top?
