"Better than nothing" running the stock shaft.
I disagree with not setting pinion angle with the stock shaft. Why wouldn't one want to make it last as long as possible ?
You do know that there is an rzeppa joint on BOTH ends of the factory drive shaft, right? You do know that setting your pinion angle so that it's in line with your drive shaft will ONLY address the joint at that end, right? In other words, you will still see a CV boot failure sooner than later only it will be at just the output shaft end. All I can do is share what I have personally seen in the last 8 years but, you're still free to disagree. :yup:
