wwood
Yes. There is no need to set your pinion angle with a factory rear drive shaft as it has rzeppa joints. They will not have vibrations. Having said that, depending on how much lift you have, your cv boots will be in a constant state of pinch and that will lead to them failing prematurely. This is especially true on a 2-door. Also, not all adjustable rear upper control arms will allow you to set them short enough to return things back to stock.
Thanks for that info. I am running 3" EVO Plush Ride coils and the factory rear drive shaft CV boots do not appear to be pinched much at all so I will shorten my rear uppers a little and see what happens (I do have some adjustment available).
