stweasel
Quick tips. Take a wide mouth Gatorade, drink it and use it for a piss bottle at night.
Make sure you don't buy lemon lime as you don't want to pretend you are Bear Grylls. If you don't camp often just get the foam pad for $20
You're camping in Tennessee and Alabama, not inside the Arctic circle. You'll be okay.
Some of these basic gear requirements have been mentioned, but I will repeat:
(1) Insulated sleeping pad.
(2) Properly rated sleeping bag.
(3) Properly rated and set up tent. (If you will get rain or snow, you better make sure sure your tent's seams have been properly sealed and you better make sure you know how to properly set up and stake your fly to ensure it is not touching the walls of the tent.)
(4) Appropriate clothing used in layers. Appropriate footwear and at least one extra pair of socks.
Tips:
(1) Don't sleep with much in terms of clothes on (maybe just a thin long underwear base layer.) If your body heat isn't reaching your sleeping bag, you aren't getting the insulating benefits of the bag.
(2) If your head will be outside of the bag, sleep with a warm hat on (you lose a lot of heat through your head.)
(3) Don't go to bed feeling like you have to take a dump. It takes a lot of body heat/energy to keep a dump passable in your body. (TMI, I know, but I promise you will sleep warmer if you drop the kids off at the pool before climbing into your bag.)
(4) Hot water bottle in the bag is a good way to start warming up the bag before you climb in, and it will preserve some of your body's own heat energy.
(5) Don't drink alcohol. It will absolutely make you sleep colder, and it will also likely cause you to have to take a leak in the middle of the night.
Personally, I'm not a fan of propane heaters. They can kill you in a number of different ways. With a little gear planning and knowledge, you can comfortably camp in sub-freezing temps with no issues and no reliance on propane.
Well shit bro, I appreciate you telling me everything I already know. I should have stated in the title that I needed USEFUL advice. My apologies.
Move along now.
Move along now.
Well aren't you a badass. In that region in November it might be lows of 20's at night time. A tent, sleeping bad, some sort of sleeping pad and a camp fire.
Maybe you should just take your mommy to hold you instead though.
I don't know, In a year that Alabama has already lost to Ole Miss and potentially State...It could get mighty cold in Alabama for a Mississippi boy. Hotty Toddy!! Wait a minute you cant go camping the week of the Egg Bowl!!!!! You some sort communist?
All good advice ! I go cold weather camping for deer and elk hunting all the time and can add a few bits... Tent, and rain fly! got to prepare for the worst and you got to stay dry! Sleeping pad a must and good bag (doesn't need to be a special 'sub freezing' bag, just the normal thick cotton cloth type(I hate the slick nylon type (too cheap and cold)) thats rated for 30 degrees and above is fine but I take two and a heavy old wool army blanket. It's the same as layering on the clothes... layer the top of your sleeping bag with the extra bag and heavy wool blanket...IT WILL keep the heat in your sleeping bag. In extreme cold, a beanie on your head at night does keep your body heat in as your head is sticking out of the bag and you lose a lot of warmth that way.
Heater... I use a propane one just to get the tent warm or as I'm changing clothes but never through the night and always be careful not to knock it over as tents are small and always full of flammable materials.
Personal clothing... as everyone says... layer! A set of 'thermals' top and bottoms make all the difference in the world to help hold body heat in and the wind sucking it out of ya. Pack extra clothes just to have to keep dry. Weather tight boots are good because once they get soaked and you get wet, cold feet, the fun has ended!
That's my two cents.... Good luck and have fun!!!
Just camped this past weekend at Rausch Creek. 27 degrees and some snow showers on Friday. It was great. The Jack Daniels helped a lot along with my Gatorade bottle. View attachment 110407
