i just leave this here for myself!
I stand corrected! I just need to build the platform now, so I can access the storage space below.!
I have the 37qt and with it sitting flat in the back I can not have my tuffy security deck in.
Sub'd to this. I'm still searching for a deck that will fit for an ARB fridge as well. Tuffy sites too low and my trektop nx limits the amount of space I have in the rear to run most of the decks that sit higher than the top of the tailgate. Besides fabbing your own (which I may end up doing), does anyone know of any high-sitting cargo decks that would work with a trektop?
I found this picture. This may work for those that want the smaller 37qt fridge. That is a Garvin rack. I think Ace makes a rack that sits up high. A google search will probably turn up results.
That would be a MAJOR pain in the ass on the trail in terms of getting anything out of the fridge while loaded up. I suppose you could put the fridge on a slide, but then it might not fit under that rack.
The short deck is by far easiest solution. But it does limit how much cargo you can secure.
How do you have it setup? I am currently using a masterlock cable with built in lock, that goes around the rear handle and to the drive side roll bar. Still thinking of what other methods would be better for security.I keep my fridge in the jeep almost all of the time but it is secured with a cable and heavy duty padlock.
I've been trying to figure out a fully enclosed top deck solution for a while now. I don't have an ARB yet, but my cooler is pretty much the same dimensions. Just higher than a tuffy deck.
Building a high security type deck is a bit more difficult because the goal would be to make it sturdy enough to support gear, etc on top. To sharkeys point, would have to then run a slide or piano hinge the top on the side the fridge is on. Plus, making it sturdy at that height is a bit more difficult as well.
And this all seems to work against each other. You want an ARB fridge to carry lots of food/drinks, but then if you are out that long, you need camping gear/clothing and tools, which does not leave room for the ARB fridge. I think that the ARB fridge is awesome, but it all comes down to space. That is why I think that freeze dried is the way to go. If I have 4 people in the JK, then I would need to likely use a trailer of some kind.
Just my two cents.
