You can view the page at http://wayalife.com/content.php?190-Jeep-JK-Wrangler-NV-241-NV-241OR-Transfer-Case-Service
So long as it states on the back that it meets or exceed MS-9602, you should be good to go. That is what Chrysler recommends.This Fluid is ok for my 17 JKUR Auto... right?
The Back label reads: "..... transfer cases requiring Dex/Merc or ATF+4 fluids"
Hmm... looked on their website... doesn't say that... only their ATF4 trans fluid says that. This one just says "FCA Dodge & Jeep."So long as it states on the back that it meets or exceed MS-9602, you should be good to go. That is what Chrysler recommends.
Hmm, I’d be hesitant to use it then.Hmm... looked on their website... doesn't say that... only their ATF4 trans fluid says that. This one just says "FCA Dodge & Jeep."
If you're servicing the T-Case, you'll be fine. If you're servicing the automatic transmission, get the Mopar ATF+4.This Fluid is ok for my 17 JKUR Auto... right?
I'll just swing by Jeep Tomorrow and get the right stuff.... Thanks guysIf you're servicing the T-Case, you'll be fine. If you're servicing the automatic transmission, get the Mopar ATF+4.
Just get ready to bend over at the Dealer. Going to be super expensive.I'll just swing by Jeep Tomorrow and get the right stuff.... Thanks guys
Yeah I think I paid $32 or something a quart. The manual transmission fluid is even more. Of course it takes like 1.25 quarts too...haha.Just get ready to bend over at the Dealer. Going to be super expensive.![]()
I've used that stuff. Works fine.Saw this one so I grabbed a couple... should be good. And only $11.
View attachment 372299View attachment 372300
