Yeaterday I have reprogrammed the wheel diameter...today I'll check if someting is working different ...
what programmer do you have?
I had a similar issue on my 2010 automatic transmission, I was just about to give the OK to send it out for a rebuild when I decided to reboot the PCU.
using your programmer, return everything back to stock
with the engine off and stock tune installed, disconnect both the positive and negative cables from the battery.
touch the ends of the pos and neg cables together then leave it for 15 minutes disconnected
after 15 minutes connect your battery, start the motor - do not drive it, just let it run for a few minutes then shut it off.
install the tire size calibration, remember for an accurate tire size measure from the center of the hub to the ground then double it. If you measure from the top of the tire to the ground, measure from the outer edge of the top tread to the ground.
once you finish installing the tire size take it for a test drive, hopefully that will resolve the issue.
Today I have tested your procedure...tomorrow I'll see the results... Thanks in any case for suggestion!
First test no good! At the stop the engine was close to shut down!
After few minutes everything seemed working properly but the oil temperature of gearbox was higher
Tomorrow morning I'll test it again...if not ok I'll go to the dealer...
Ok, get ready to go ahead and make fun of me. I had a similar issue where as I came to a hard stop from about 35-40mph it felt like the jeep was slamming down a gear at the moment I stopped moving.
It had been like this for a while so I just stopped braking hard. Problem solved lol. Last week I checked the transmission oil & suddenly the issue went away. The only other thing I've done out of the ordinary was go rip through a muddy field.
Could there be a vacuum issue if the dipstick isn't inserted back all the way? It does click & lock into place?
Check your dipstick. I know it sounds crazy & I'm a newb so I totally understand if this sounds ridiculous.
I'll keep you updated!
Unfortunately after some test the gearbox still has the same trouble (or it is not a trouble…?).
I don’t know if can I make different check or test but for the moment the gearbox, when the oil is cold, i.e. at the stop in D mode, seem that didn’t disengage completely the traction…
The shifting is always correct and after few minutes/Km it start to work properly also at the stop light…I’m confused…
