Only had half a day but I still got a lot done. More of the fun projects that make the interior nicer and more comfortable, small things that make you happy for the daily driving.
The driver door panel has been cracking more and more, started after some trail damage but it's time to address it as I had the panel off anyways fixing he door lock solenoid.
Not going for beauty as the entire door will be replaced at some point, but enough to stop the spread and give it some rigidity
Some epoxy and a couple pieces of scrap metal and it's a lot better.
Most the day I spent addressing my dash issue as I have never really finished or decided which way I wanted to go with it. It pretty much sat in my first mockup duct taped together for the last year.
How it was, gorilla taped up and Hvac controls flopping around
Detailed fabrication has never been a strong suit for me and I still have to finish the outer plastic trim piece, might pickup a new one of those and start over. But overall I'm very happy with how it came out.
I've been wanting to play with these COB led lights for awhile so I picked up a few for cheap on amazon. They claim they can be used for drl and exterior, there is no way in hell these are even water resistant. They also use a wire so tiny that I couldn't even strip the insulation with the smallest wire stripper I have. However, they are relatively bright. So I clipped off the old lightbulb housings under the footwells and soldered these onto the connectors.
Not bad, we'll see if they last.
Next up is the winch connection. I have a lot of extra parts and wiring for this winch and I wanted to put a remote connection inside. So I picked a spot, drilled it in and ran the wires.
And brought the wires to the solenoid box I have mounted on the inner fender. And will hardware them to the solenoid tomorrow.
Now that I have an easy access hookup I wanted a much shorter remote so I cut about 8 foot of wire out of it and soldered it back together. Now I have a nice small remote that can be kept in the glove box not taking up much room.
I have another full size remote that I will keep in my full recovery kit that I can still use outside the vehicle if needed.
Sent from my iPhone using
WAYALIFE mobile appb
