Okay, just checking. All things being equal, there is only ONE thing that keeps your axle centered under your Jeep and that's your track bar. Either what you have is bent, your frame side mount is bent or you got way more lift out of your kit than you were expecting. If everything checks out and nothing is bent, you need an adjustable track bar to re-center your axle.
I think we're all confused, is there a lift on your Jeep or is it stock?
Are the pics stock suspension or post- lift?
It was a salvage title that was hit on the passenger side. I was told the frame was checked and everything was fine, but I never got documentation so that could have been bullshit. I think ill start with getting another track bar to put up next to mine to ensure its not bent. If thats not the case I may have to just pay someone to check the frame.
Ah! I guess I missed the part about your Jeep being a salvage and that it got hit on the passenger side. If I could guess, the forward most cross member is slightly bent. It's a tube with bends in it already and so it would be difficult to see if it was bent more than normal. Assuming everything else about your Jeep is fine, I would just get an adjustable front track bar and call it a day.
Fair enough. im going to get under it and do some thorough inspecting after it starts to dry off from the rain last night and see if I can find some potential indicators of what the problem could be. Any recommendations on adjustable track bars?
Of all the track bars I have installed and tested out, I liked the JKS as it had bonded rubber bushings on both ends. Clayton was a good choice too. I would just try to stay away from ones that have polyurethane bushings or heims as they tend to get noisy. I would also stay away from ones that only have one bend in them like Rubicon Express as they tend to have clearance issues with the diff and bend even more. I would also stay away from TeraFlex as I have flat out seen them break and, while they will take care of you, they will say it was your fault.
I second skipping synergy, noisy pos.
Don't tell this guy...
http://wayalife.com/showthread.php?23456-Shock-ques-for-4-quot-lift
:crazyeyes:
Lol, that's brand loyalty right there.
