I've had both and I can't say one is better than the other. I think the bfg offers a heavy duty sidewall. If you can't decide then go with whichever is cheaper.
How are the new KO 2's? What size do you have? Or did you have older KO's?
I haven't used either yet myself, but I can tell you that the miners and people that maintain the ice roads up here have sworn by the Duratracs for years. That's mainly because up until this year they have really been the only winter rated off road tire, and they have had proven excellent performance in ice and snow. They even let you add studs if necessary. That said, the biggest complaint about the Duratracs I've heard is that they have weak sidewalls that can't take quite as much abuse on the trail. I've heard of people running these year round down south, but if you don't need them for their winter performance, I think there are better tires out there.
The KO2s are a much more modern design, not just considering that they are brand new. I've yet to hear a side by side review with the Duratracs, but I do know that their sidewalls are designed to be much more durable. I think their only big draw back (for those who live in an extreme winter climate anyway) is you can't stud them.
Also, have you looked at the new Nitto Exo Grapplers? They also came out this year, and they are very comparable to the KO2s in terms of design. They can even be studded like the Duratracs. I was actually leaning towards getting these until I heard that the KO2s will be sold in a 37" size in the spring.
The 37 KO2 will be a small 37 so if your looking for maximum tire height they will fall a little smaller then TOYO's
Where did you hear that about the KO2 sizing?
Also, which Toyos do you mean? I've looked, but they don't appear to make a winter rated off road tire.
Look at the specs, if they follow the the original KO's which run small as well, so do the mud terrains they produce
That sounds like a fair assumption about BFG tires in general, but the 37" class KO2s will still be the largest winter rated off road tire, and they'll also be the only ones in the size range I want to run. Otherwise, I'd have to compromise and run 35" tires.
It doesn't sound like winter performance will factor into the OP's decision too much (and I'm sorry if this is turning into too much of a tangent), but I can't really consider using anything that's not winter rated up here.
