Let me know if this helps. View attachment 283168 View attachment 283169
You may want to check out some of the hot rod shops. They typically offer custom brake line configurations.
I will post up a pick in a few days, I have my rear axle completed and my front removed and prepped. After seeing this thread, I notched out a small area of the caliber with a dremel so that the banjo fitting will fit at 90 degrees. Took maybe 20 minutes for both sides and was simple as the axle was not installed and had plenty of room to work. Once finished it fits perfect.
Sounds good! Thanks!
As promised this is how I altered my PR60 front brake calibers, I used a dremel and just cut a small piece out to allow the brake line to fit at 90 degrees then I carefully bent the steel tubing upwards to be more vertical - also touched up the bare metal with a little primer. I added the Teraflex JK Front brake line anchor kit to keep the lines away from the shocks - may not have needed these but I bought them a few months ago so I thought Id go ahead and install. Just a disclaimer - haven't field tested anything - this is just my initial install but everything looks good so far and seems like it will work well.
View attachment 283368 View attachment 283369
Just a slight bend - may not have needed but , It wasn't difficult.
No on the hydro (haven't got that far yet), just getting things wrapped up today , will measure and order driveshafts soon. Jeeps taking up the whole garage and wife isn't thrilled parking outside
I just came across a picture of Spicy Chicken and noticed they are running an XD60 front axle with the brake lines setup like yours. You may just need to re-route your lines from the frame. I'm going to flex mine out double check my lines at full stuff and will let you know if I have problems before you change your orientation.
I'm just wondering if it's pinched at full lock sitting in the garage... what happens at full droop or full stuff and full lock? Sounds like your lines are too short or not routed properly.Shaved about a 1/16 off the end of the banjo fitting and rotated them 90 degrees. Worked perfect. Took out the tight pinch point on the cable when turned full lock.
I double checked mine at every orientation with tires lock to lock and I am going to keep mine rotated up for now. I know Spicy Chicken has them rotated away from the calipers, but it looked like mine will have issues with the lines hitting the tires. They could be running a non-standard brake line though.
