steve_r2
Ok…..had an issue with driveline vibrations after doing gear swap to 4.88's
Ended up changing front and rear drive shafts, engine and transmission mounts.
Vibrations were a lot less but still there. Had alignment done and found I was way off R to L.
Then decided to get rid of my AEV drop correction brackets and get adjustable front lower control arms (Teraflex).
Shop has now aligned caster to 4.4* both sides……however on driving still get low grade vibration from 65 mph onwards….
So do I try and bring the caster back closer to 4.2* to help eliminate this vibration completely ? or increase it ?
All bearings, bushings, torque etc have been checked and are ok….post gear change inspection is fine as well.
I have read Eddies write up on caster adjustment…. and though seems straight forward just not sure I am confident of getting right as yet (total noob at this !!)
2009 JKU Auto, AEV 2.5 " suspension, Teraflex front lower adjustable control arms, 33's measuring 31.5"(E rated), winch and Warn bumper
Cheers
Steve
Cheers
Steve
