JT@623
That’s my question shouldn’t the top spring be a different rate ? To me the 250 /250 could just be one long spring that’s not a dual rate .Nice I’m at 4.5 and had to run 250 up top with 300 for the bottom
You’ve met my ole ladyThat’s what she said
Setting your crossover nuts at ride height is part of initial set up of coilovers.So got the coilovers installed today but on the font both springs are 250’s so how is that a dual rate the cross over rings ain’t even close to the slider ? The rears are 200 over 250 .
I get what your saying and yea I think your right.That’s my question shouldn’t the top spring be a different rate ? To me the 250 /250 could just be one long spring that’s not a dual rate .
On the fronts the cross over rings are bottomed out and still not close to the sliders . The ride is stiff only one inch of preload.Setting your crossover nuts at ride height is part of initial set up of coilovers.
It’ll ride like shit the first few hundred miles. Go out on some of the washed out roads and just beat on it. They will soften up. Also check to make sure the shocks are charged. They don’t always come charged. You can at least buy a nitrogen gauge on Amazon.On the fronts the cross over rings are bottomed out and still not close to the sliders . The ride is stiff only one inch of preload.
I’ll try that checking the charge today and and a few loose ends to tidy up then I’ll go beat on it a bitIt’ll ride like shit the first few hundred miles. Go out on some of the washed out roads and just beat on it. They will soften up. Also check to make sure the shocks are charged. They don’t always come charged. You can at least buy a nitrogen gauge on Amazon.
Also the other thing, it may ride rough on the street. Most coilovers do if setup properly. And by rough I mean rougher than coil and shock but they shine offroad.I’ll try that checking the charge today and and a few loose ends to tidy up then I’ll go beat on it a bit
This is false. With 250lbs of force both springs will compress an inch giving you 2" total. Effective spring rate is 125#/in. When you hit your ring and switch to a single spring you now have 250#/in rate.That’s my question shouldn’t the top spring be a different rate ? To me the 250 /250 could just be one long spring that’s not a dual rate .
