The answers to your questions are yes. Although I'll probably do hand drawn animation. Don't use toilet paper to soak it all up. I found pieces will get stuck to all the bolts and is a pain to clean off. However I didn't try Charmin...hmmmmWill you be doing a video. It would be helpful. Also, will a Cham wow pick up the water 20% faster or do you think that is overkill for the type of water you encounter. Also, if you were have a second chamois on the outside of the tire while the first one was being used, could that absorb the overflow before hitting the tire and more importantly, the ground. Sorry for all the questions. I just want to buy once and do it right.
TeraFlex makes these water removers. They're probably made in China so I don't know how long they'll last. Adjustable so they're compatible with all beadlocks. You get four so you can do all the wheels at once.
You should see the hot chick in the marketing video. ��
Yep. Only way they could sell off the excess inventory. Through auto parts stores.These water removal devices are illegal in California now, no?
Coriolis effect has not seemed to affect the effectiveness of wiping clockwise or counterclockwise. My recommendation is to use proper ergonomics and position of comfort when performing this maneuver as to prevent an injury. One could jack up each wheel, place the T-case in N, and hold the chamois in place and spin the wheel.Does one wipe counterclockwise if your above the equator? Should one jack up each tire when performing this maneuver? If your right handed, do you place your left knee or right knee on the ground?...I would hate to incur injury by not using correct form.
I think a video with some thump thump thump music would be helpful...
Hope you found this helpful. I had some time to kill while waiting for the rice to cook.
This technique will work with any "deep dish" wheel such as dual rear wheels as well.Will this same technique work with rock ringless beadlocks???
Forgot to mention. You can wring out the chamois into a plant or something else which needs water as to be more eco friendly and make you feel better about driving a jeep.
