Dorman exhaust manifold cracked in 3 months.
Colorado4
08 Jeep Wrangler JK exhaust original exhaust manifold cracked at 54,000 miles.
Replaced with Dorman exhaust manifold, cracked in 3 months, 3100 miles.
Stock mopars on back order until June.
Bummer. More than the lack of power, one of the things I really hated about the 3.8L was the manifold cracking all the time.
Cousin Clyde
I imagine Dorman would replace it for free. They seem pretty reputable. Maybe had a QC issue with a bad casting. Is it a cast part?
monstrousmac
So I found a way to prevent it. At least it worked for me and I know it sounds crazy but hear me out. I have changed 3 out on my 2010 JKU, I went to a local exhaust shop here in Tucson AZ. The technician who is a friend of mine installed a new one, I believe he got it from NAPA, so I am unsure of the brand, but he took of the installed heat sheild that comes attached. He said he has found when you remove the heat sheild for what ever reason they dont seem to crack. My 4th one has been on for the last 65K miles and still has not cracked, knock on wood.
JimLee
Unfortunately, Doorman products in my experience are hit or miss in quality. I've woked at a few of the auto part retailers (part time while I was in the military and stationed stateside) and Doorman products were almost always one of our highest return items. I'd love to go to their aluminum oil cooler on my JL, but worry that might actually be introducing a problem.
Cousin Clyde
Interesting. Appreciate the experience. I have no previous experience with them. I’m hoping for the best on this damn oil filter housing.
In steel construction equipment, I’ve definitely handed some brand new equipment back to my vendors because I can see visual impurities in castings. New one comes, looks clean, no problems.
Sounds like this problem may also be inherent to the ol 3.8 regardless of manifold manufacturer???
JimLee
Yea, the 3.8 seems to have a rep for eating those manifolds. I don't think all the Doorman stuff is bad, but form what Ive heard they farm out most of their manufacturing to many places, and they make a million things, thats probably why the quality doesn't seem very consistent across their products. Let us know about the oil filter housing, I'm still interested in the one they make for the 3.6, luckily I haven't been forced to make that decision yet
Colorado4
Well the dorman replacement lasted 4 months this time and has since cracked... At this point I will try the suggested method above and remove heat shield.
jeeeep
on my 2010 JKU I've used dorman, crown, omix-ada all cast iron, all have cracked.
I've driven the JKU about 500 miles since they were last replaced, and the driver side is already cracked.
Mopar has discontinued the manifolds for 2007-2011 3.8L
Thinking about spending the extra money for ductile iron manifolds from AFE
Colorado4
I thought of stainless but heat tends to melt plug wires. I saw the dorman instruction sheet and it says "correct mounting surface runout prior to installation or new manifold cracking will recur." I suspect mechanic thought it was a normal replacement and did not bother correcting surface as instructions said. That's prob a clue.
jeeeep
What about tube headers?
I tried a set of Gibson headers, aside from melted wires which I replaced and wrapped with heat sleeves, my JKU never ran smooth and removed them after 200 miles. I figured that was ample time for the relearn curve.
