Worst Driver
Wow that is a really good deal!! Here there are not a lot of options in my area
Sent from my iPhone
Sent from my iPhone
Do you know if they were still running 30 spline shafts with the 40s?
No, I think they run 35 Spline RCVs, but I could be wrong...
Negative. Haven't run RCV since Nemo. Rubicat is running a ProRock 44 with Rubicon 44 internals - factory 30-spline shaft. It's why we didn't run 40s for long. We would break something for sure.
Watch WAYALIFE YouTube Videos
WAYALIFE Jeeps & Specs
It says it has 3.21 gears, does d44 come with those, or does it come with 4.10.
This actually might be a
Edit
Never mind I tough it was a front axle, sorry [emoji52]
MY BUILT/REBUILD: http://wayalife.com/showthread.php?44123-Rebuilt-of-a-Billet-Silver-mall-crawler&p=859931#post859931
Hey guys, I'm in a bit of a predicament and I hope you guys can give me some insight and steer me in the correct direction. I was involved in an accident a couple months ago, and I received a payout for a new rear axle. The total amount is $2600.
The first thing that came to mind was Dynatrac! But then came the question of figment, what else would be needed, could I reuse knuckles, can I swing simply a DT housing with new shafts and reuse the rest?
I don't have a lift yet, I was still saving up to go with the Evo Enforcer. I did some reading and saw DT axles don't mesh up well with non-lifted jeeps without cutting/modifying.
I hope you can help out. Any advise if greatly appreciated [emoji106]
Sent from my iPhone
Sorry to hear about your bad luck, hopefully you were uninjured and your Jeep not too badly hurt in the accident.
As mentioned before, we do offer a direct replacement ProRock 44 axle housing that will bolt right up to your Jeep. But it would also be a good time to upgrade some internals over stock as well. Give us a call at 714-421-4314, one of our techs will go through everything with you, and figure out what would be the best package for your needs and budget.
No they don't. It's probably because going to a high pinion 44 running on the coast side in the rear of a heavy JK would not be a good idea.
