Look at it this way; you now have the perfect excuse to upgrade front shafts:brows:
Ha ha! :rock:
Maybe so. It did recommend RCV as a fix basically.
Damn..
So I'll just modify the yoke and be very careful. Definitely won't let it get too warm.
I'll make sure to post as the install
Skirmish broke a shaft u-joint on our marathon run and I let him have the stock shaft from my stock axle. Both of our jeeps are 2012's but mine had the revised larger yokes. He had some rubbing when we swaped the shafts out but it was very very *minimal. I cant remember if he even had to actually grind it down...I dont think so. I think he is running synergy ball joints but I also think it was rubbing on the brake caliper bolts and not the ball joints in his case. Maybe install and see how bad before you grind it down.:idontknow:
Mines at 2012 and those RCV's do take up some room. I did not grind anything.
The axles have been ground down and the Jeep is all back together and everything clears :wings:.
Nice work! This write up should save some people some headache. :thumb:
Great job there. :thumb:
so I'm wondering what your blood pressure was before and after :thinking: nice work...
I'm replacing ball joints this weekend if it's not hotter than hell ...
lol Well it was hotter than hell here. I set up my 10x10 popup shade in the driveway and a fan to help. I don't think I'd have done as good a job if the sun had been cooking me while grinding. :crazyeyes:
Will you be installing the Dynatracs?
My blood pressure wasn't bad. It just takes a little time is all. :thumb:
That looks like a massive pain in the ass. Do you know if you only encounter the clearance issues with the lower ball joints or the uppers too? I know you replaced the lowers due to failure, but wondered if you've had any issues with the uppers too.
