Dynomax evolution exhaust on 2door
Does this install of the dynomax exhaust require
Cutting??
it shouldn't. everything should be exactly the same up to the tailpipe. if you got the version that routes to the very back, maybe but, you got the evolution so that won't be the case for you.
I was reading the instructions. It says to cut 2 1/2 inches off of the outlet?
Hmmm, well, I suppose they would know better than I. The only thing I can think of is that the cross member that the exhaust hanger attaches to is physically in a different location than it is on a 4-door. In fact, the more I think about it, the more it would make sense.
It says to cut off the pipe in the instructions I received too (4 door). I couldn't figure out why you would need to. And it wasn't in Wayoflife's write up. So I just dry fit the whole thing to see if the hangers lined up. That's what I would do if I were you. :thumb:
I guess I'll try and make sense of it when I get underneath my jeep with it. . Would the instructions be the same for the 4 door and two door ? Cuz I know it fits Both
