ECTO- JK Build Thread
RockIt Man
Thanks Bondsy.
The spread sheet is actually a little more than I am capable of doing, but it was just a lot cleaner than all of the lists I make on every piece of scrape paper or junk mail that I find.
The colors actually represent different things. Green means I already own, red is I have to do first, and yellow are things to do soon after.
piginajeep
The Original Smartass
ProfessionalDriver said:
I have my build on a spreadsheet too, but mine has dollars attached to each item and phase... What was I thinking??? :grayno: :broke:
Nerd! I'd rather not to the money I have into my jeeps..,
Sharkey
Word Ninja
Same here. Had the damn spreadsheet for nearly four years now. I have to go in and change it now because I sold my '09 and the build of a 2013 will be different. I also have a folder with a color picture of each item on the spreadsheet. Yes....I'm a total loser.
MTG
This is why I just use Sharkey as my spreadsheet.
:cheesy:
:cheesy: just started to catch up on this thread. the first time we ever put all our parts on a spread sheet was also the last time. ignorance is bliss :yup:
LoPo
I only put together a spreadsheet for a major upgrade/at the time of that upgrade planning/wife buy in. Had one for my visit to ORE last fall, because well there were a TON of parts and trying to manage the total cost off the top of my head was :crazyeyes:
I'm gonna assume the OP is some sort of Project Manager though, as that seems like something I see at work often. :)
MTG
Agreed. Started adding mine up and stopped before I finished. Better to not know and wonder....
RockIt Man
I think it's funny how many comments the spreadsheet is drawing. And not so much the actual build plan.
I'm a firefighter. Very little computer use at my job. But I do find myself planning out a lot of my own personal projects.
jktubby
I too have a spreadsheet with prices, I hate seeing the total cost at the end hahah, but it gives me an idea of how much money i need. :thumb:
Must have a lot of time on your hands huh. lol
Prime8
I too have a spreadsheet, broken into divisions like yours. I also have three colors... Green is stage 1, yellow stage 2, and red is stage 3+... The D60's are highlighted in red...
RockIt Man
Sleeve Dana 44???
I'm planning on upgrading to 40 x 15.50 x 20 tires while still running stock Rubi Dana 44's (eventually plan on running PR60s)
I will def be adding EVO C-Gussets prior to adding the meats.
I am well aware of the added stress on the ring and pinion and axle shafts...
My question is, is it worth it to sleeve the axles??
Any personal experiences?
Thanks
Hightower
I will def be adding EVO C-Gussets prior to added the meats.
Thanks
I have run 40x13.5x17 on stock 44 with both the gussets & sleeve I didn't have any problems I have since gone with pr60's. I would suggest upgrading when and if possible.
RockIt Man said:
Anyone running 40s on Dana 44s??
Yes
RockIt Man
Which Upgrade next???
I have an EVO Enforcer lift with 4" coils ready to install on my Rubi. I will be running this kit with 35s
Question is in what order should I install these needed upgrades...:hmm:
Drag Link Flip Kit
Adjustable Front Trackbar
Front Driveshaft
Sector Shaft Brace
Are there other upgrades that should take precedence before any of these items..?
Thanks in advance:thumb:
MTG
Drag Link Flip Kit
Front Driveshaft
Sector Shaft Brace
Drag link flip kit at the same time as the lift if you can. Then driveshaft. I don't know why you would need an adjustable trackbar. I'd get skids and rock rails if you don't have them already.
RockIt Man
I didn't grab the flip kit with it. So I was assuming flip kit first then the driveshaft.
I was under the assumption that any lift 3"+ shifted the front axle over and it needed to be recentered. :idontknow:
I currently have the Rubi rails and plan on selling them off to buy EVO skins and rails.
Any thoughts on the sector shaft brace?
MTG
I didn't install the sector shaft brace so I can't help you there.
The enforcer kit comes with brackets that relocate the track bars. You will not need an adjustable one.
