Enforcer lift install
atrollip
When the arms moves or flexes to the right it will almost touch. But ORE said its close but it wont touch.
We turned bolts on lower shock mount around to give clearance. I have a CRD so engine upfront is heavier meaning the coils don't give the full 3" lift in front and control arms are flatter in angle.
That being said turning the bolt hasn't seemed to give us any issues.
Sent from my SM-N9005 using WAYALIFE mobile app
MericaMade
And did you put both your driver and passenger side sway bar links on the inside of the sway bar or just the passenger side
I ended up going with 11 1/2 inch sway links and moved them back to the outside like they are supposed to be. I went with a 3 inch loner sway link vs the 14 inch one EVO put in the kit.
