MTG
Got it completed, had to wait for a buddy to help with the brakes. All in all a pretty decent install, pretty straight forward all the way through.View attachment 12037View attachment 12039View attachment 12040
Looks great atch!
Atch...those Kings look awesome! I'm sure the ride is even better:thumb:
Thx man, I really liked the ride of my old kit but these coilovers take the bigger bumps on road a lot better. I haven't had a chance to flex it out offroad yet!
Anyone else having issues with the springs sitting slightly slanted?
What do you mean, do you have pictures?
Make sure you adjust the two silver rings about a half inch from the upper spring. That should quiet them down.
Yeah but look at your bump stops. This system is designed to have miles of droop but not much up travel. There are only a few inches of up travel including squashing the bump stop, and it will settle even more after several months. So you want to transfer the load into the secondary spring within the first inch of up travel. When you drive over multiple bumps, the Jeep will "float" a bit higher since it won't settle back down after the first bump before you hit the second bump. So in actual off-road use you will get more use out of the top spring than it appears....That doesn't seem like it would allow your top spring to do much?
Dave
I see you have them mounted in the normal shock mounts on axle. The kit comes with plates to push out the lower mount. They would be sitting less crooked then. Any reason you aren't running them?
