KernHydro said:The way your going I'm surprised your going with bolt ons considering your getting Dana 60s and 40s it seems you should be getting a weld on system and a better rear coil over setup like the evo lever
In the world of coil overs, the bolt in system is bottom end. I'm not saying that it's cheap or that it sucks. But it is not evolever. Do you have a coil over set up? Or have you just seen pics of your friends uncle that had them and they are super cool? King is the leader in coil overs, yes. Evo mfg makes some good parts, yes. But bolt on parts will always be lower performance that custom parts. Even if that difference is only 2.5" or whatever...
^^^Agreed ^^^. Your planning a huge set up and awesomeness, then going bottom end on coil overs. Why didn't you pick the evolever??
Most of you people are missing my point on bolt on and bottom end so forget it.
So far the only thing Im not stoked on is the rear coilovers are in harms way. Not sure if this will be a problem but for chris having 40s etc the lever seems more fitting as I would imagine he is going to get into some next level $h!t that might have him doing a little backing up and thats were there could be a problem with hitting a coilover on a rock. Either way he is winning ...king is well KING
Why would you pay someone to install the evolever and weld on coil overs? If you don't have the skill or tools, don't you have friends that could help you out?
This makes since had not thought about the higher mounting of the coil and it straightness . And as chris said the departure angle of the 40s is going to help as well. Have you had any close calls with the rears yet or any advice on avoiding damage?the use of rock stars to get the lower mounts higher up off the ground and armored up/skidded. it also includes a more vertical alignment which not only helps to keep the coils way from the rocks but, also helps to provide a better falling rate. for the price, you simply cannot get a better setup.
StrizzyChris said:Just got mine today!!! Now the wait begins until I head to Ohio(in a month) for the build!
