turbineguy
Because icon suggested it. Along with AEV drop brackets.
No one mentioned drop brackets.
Yes I know you were just being a smart ass.
Sent from my SGH-M919 using WAYALIFE mobile app
Long arm won't give you more flex.
So I could run a short arm with the Evo Long Travel coilovers and still get full flex?
Agreed. Long arms would make no sense at all and I don't think they would provide any benefit.
Yup piginajeep is doing it with all factory arms except for front lowers. Same with ttfhell. And both ran the JKX.
And they don't sell those travel coilovers on their website anymore.
http://www.offroadevolution.com/store/proddetail.php?prod=EVO-COILOVER
Somone forgot to tell Evo.
Okay.... WOW!!! Sorry for the late response to this. Let me try to clear some of this up :shock:
EVO MFG currently has TWO (2) Coil-Over systems -
FRONT / REAR LCG Bolt-On Coil-Over (which is just that - BOLT-ON) - sold separately
FRONT / REAR DTD (Double Throw Down) - sold separately
So the main difference (other than ONE being BOLT-ON and ONE being WELD-ON) - The LCG Bolt-On Coil-Over system is designed to replace your shock and coil with a CUSTOM Built CUSTOM Valved KING Coil-Over using a simple bolt-on application (does require some cutting / grinding). The DTD (front / rear) is a WELD-ON system can be run with a stand-alone coil-over OR coil-over & bypass (once again - front and rear). Now we have a number of customers running the DTD in the front and LCG Bolt-On in the rear as well as customers running the front DTD with stand-alone coil-over and LCG bolt-on in the rear with the plan of upgrading to the 3 tube bypass.
The LONG Travel Coil-Over kit is the old SINGLE coil-over kit that we are actually no longer offering and I am thinking that is where there is some confusion (since it is still on the website)...
note - The LCG Bolt-On Coil-Over kit is NOT sold without the Coil-Overs and sold ONLY as a complete kit.
no they told us... we just have not taken it down off the website. it will be removed monday to eliminate further confusion.
running long arms on a jk with a small lift (1-3") or 35 or smaller tire will achieve little to no benefit. your travel is going to be gain/limited to the length of your shocks and not your control arms.
If there is a chance that I will go to a higher lift in the future should I just invest in long arms now? Will long arms hurt me at two and a half inches of lift? Are there short arms that are adjustable on vehicle like your long arms? Why does rock crawler offer a 2.5 inch long arm system?
Okay I'll say what it seems others are beating around the bush about.
Plain and simple. If you want 1-2" of lift and 32-33" tires, save yourself ALOT of money AND time, get some spacers or a budget boost. If you want a softer ride get some upgraded shocks.
This silliness about long arms with 1" of lift for a LCG is just, well silly. If you are wanting to drop some serious coin on a serious setup for serious wheeling, take your rig to Off Road Evolution, talk to Drew and get a CUSTOM setup.
first, there are LOTS of companies that offer LOTS of things that you dont NEED!
but sure you can run a long arm if you choose, but at what you are look for now, a simple set of front adjustable lower control arms is all you need. just trying to save you some money. i will be happy to sell you a doubleD upgrade, give me a call.
Someone forgot how to read/search.
View attachment 66082 :cheesy: :cheesy:
haha... who the fuck keeps mentioning 1" of lift... not me.
Icon bolt on coilovers range from 1 to 4 inches. Thats the route Im going with to keep my Jeep low. 3 to 4 inches is way to high for me.
It may or may not be a mistake. Im willing to gamble since I can easily return to stock.
Im currently trying to decide if I should pair them with the double D long arm kit or metalcloak arms. I might even try the double D arms will duroflex bushings. I like that the are adjustable on vehicle and upgradeable to high clearance setup.
I already have a simple set of front adjustable lower control arms. I'm trying to figure out what would be best for my future, given I'm planning on getting a kit that will allow 1" to 4" of lift (even though I plan on running it at first at 2" - 3" inches.). I have plenty of money to spend.
So in this case... would you recommend a doubleD upgrade?
