MericaMade
Sorry if I missed it but is this happening on the JK, JL, or both. I just installed one on my buddies JL and it went together easy and sat flush, but he said the tailgate in now drooping a little after a few hundred miles.
This is all on JKs
That’s pretty much how mine looked after tightening down. But with the inside deformation. I spent a lot of time looking at it, loosening, tightening, adjusting, etc and I just can’t see how to make it sit flush without a redesign. Smaller spacers will pull the gate closer but at the expense of the gate to tub gate...and due to the angle (the gentle bend we were talking about) on the carrier I wonder if that’s even possible. Any smaller shims and the right edge of the gate with hit the carrier. Even with the current shims, one of the joint welds contacts the sheet metal. Any less and it’ll dent it. Still waiting to hear...
Yeah I can’t remember what the back of mine looked like. Curious tho, is the inside of yours also powder coated? Mine wasn’t at all and that’s honestly my biggest gripe. I wish I had coated it or plugged the holes somehow.
On a side note...anyone ever hear of it have this happen to them? Crawling into the back the other day to check tailgate adjustment I felt the floor give way under my knee. Sure enough the cover over the tool area broke. $200+ dealer part from what I see. Thought it was stronger than that. Geez View attachment 321853
Yes, I’ve broken 2 of those in different jeeps,
Did you just replace the piece with OEM or something stronger?
So I added 1 washer to each of the bolts in the top hinge plate. Added 2 washers to the top right bolt on the plate. Plus blue loctite. Really need to get some longer bolts for the hinges.
But I did multiple combinations of washers. This seemed to yield the best combo of top passenger side not bowing out from the window and solid connection of the top right plate, bolt and body.
Hopefully this solves the issues.
Put mine on this past weekend. It seems pretty solid. It seems that if they were to machine tubing to fit in the hinge area it would add some strength to that area. Basically what they use now just seems to keep the hinges from smashing together from bolts being tightened. I did not have any ill fitting of the carrier to the gate. Not impressed with there packaging or their powdercoat AT ALL! And that goes for the Evo Rock Stars I just installed yesterday. Shoddy packing and shoddy powdercoat.
