Hi Sharkey
Just going to through this out there, but should they evenly space out the washers as it seems they have a large stack on one side of the sway bar link compared to the otherside. Just a thought but could that not eventually drag the sway bar back and cause the rubbing issue all over again? Again just a thought as I read through this.
It's top less day tomorrow ....
Just circled were we needed to put washers in just to get it to connect
swaybar looks upside down, the pivot should be on the swaybar, the open with bolt through should be on the tab
if you have the electronic swaybar it's a 2 piece, don't hammer on it trying to move it over. you may need an adjustable trackbar if you don't have a raised trackbar bracket. have you measured to see if your axle is centered?
