JKU Arizona
I just had a PR44 housing installed in my Jeep and everything from the front d44 transfered over with zero issues no additional components needed everything fits and lines up perfect. If your going directly through Dynatrac they should be able to steer you in the right direction. Its amazing how tiny and light weight the stock 44 feels after handling the pr44.Cool thanks I will check out that PDF. I currently have a Rubicon D44 front and plan to swap everything into a PR44, I figured it would work the same, was just confirming. Looks like I need the Mopar harness, sort of odd they left out the indicator light wiring though, is there one you can get so it will show as stock does in the dash?
Sent from my SM-N920V using WAYALIFE mobile app
