So I have an auto 3.6 and I'm about to move up to 35's. I have 3.73 gears. According to the chart I should be fine right until I can regear (about a year)? Bad for the trans?
You'll feel a loss of power with the larger tires but it isn't bad for your trans. Don't forget the programmer to adjust your spedo and your shift points if you have an auto.
Thanks for the charts would you advise going for a ratio in the green or blue if it's a daily driver and gets chucked around the desert on a weekly basis?
regarding the programmer..i know adjusting tire size will adjust the speedo, will it also adjust shift points or is that something else that has to be manually adjusted?
bump5678910
So I know this question has been asked a billion times but why not once more
I'm changing gears soon and have 35s
It's mainly a daily driver and am wondering if 4.56 will be better than 4.88
With the manual transmission, 4.56s and 35s would be fine. If you had and automatic, I would suggest 4.88s.
What's the difference if you don't mind me asking
I have the factory 4.10s in my 2014 with an automatic and run 35s, I love it. I think it depends on your actual driving terrain also. For me a 4.56 or 4.88 and 35s would have my jeep around that 3k RPM mark at 75 MPH and I don't like that. I was between 2700 and 3000 on the factory 32s when running 75 on the highway. Sounded like it needed another gear all the time. So for me the 4.10s work great with 35s. It still gets up and runs, goes 75-80 down the highway, and will chirp a tire (barely) if you punch it.
However, when we went to Colorado and traveled between Durango, Silverton, etc. I was wishing for a deeper gear. In the mountains on the highway it was trying to stay in 2nd gear to keep speed. So if I were to move to Colorado and stayed on 35s I think I would definitely look at the 4.56s or 4.88s. Up on the passes in 4x4 it done great. It just struggled on the highway.
