It's probably fine. Just something I think about.
Are you running factory wheels or aftermarket?
Aftermarket.
Bah. Stupid phone:
It took me a full 30 seconds to figure out what I was looking at. Good to know though. Thanks for posting pic.
Planning on pouring gear oil into one of these to take on trips. It's a container that originally held ATF+4 transmission fluid, which I sprayed out, soaked in hot water twice, and sprayed out again. Any concerns with pouring gear oil in there and then pouring that oil into my differential?
The gear oil bottles are too tall to fit in most containers, including the one I use.
Chemically shouldn't hurt anything, but you may want to clean them out the best you can with Brakeclean or something. But the tricky part is if you go to use them, it will be near impossible to get the fluid out of those and into the differential fill hole. Unless you're using that funnel thing. Also an auto parts store may have caps that fit on those quarts with a squirter nozzle that you could carry also.
In the future, CarQuest carries gear oil tubes that are small and narrow with a squirter fitting already on them. Here's a pic. Under that cap is a squirter nozzle.
Thanks Doug. Planning on bringing the funnel thingy. And a bottle pump. So should be covered there.
Does that tube actually hold a significant amount? I like the idea. Couldn't find gear oil in a quart size bottle.
They only hold 7 oz. I thought they held more than that. But I know you can get those nozzle caps for quarts as I have some.
I like that. Then just need the tubing to run to it. Amazon?
