Thanks! 16 gauge. Feels surprisingly rigid all mounted up. Eager to see how it does the compressor turned on.That looks great! Clean look. Glad it fits. What gauge steel did you use?
So...may have stayed up till 2am last night wrapping that upWhich way you are running the wiring?
If you take out your battery tray there is grommet there, you have enough wiring that came with the compressor to make the connection, no splicing needed.
Thought about that but wasn't sure what best practices are. Do you still have to put the key in the On position or do you just have it always wire to constant on even without the key in the ignition?You may want to run the ignition signal wire to a constant 12v power source so you can use the compressor without starting the jeep. Blowing up bike tires, soccer balls, using air to blow dust off the jeep, etc. We use ours fairly often at home without starting the jeep, and it is convenient.
Thanks! I'll feel better once it turns on and I know I'm good to go for sure.Wow, great job on the under-seat mount!
Trying to figure out the best option here. If I mount the switch next to the one compressor and then go thru deep water, could the water close the curcuit and turn the compressor on? How water proof are these compressors to begin with?No key on. I can run my compressor at any time. We wired the jku the same way.
Wife hates the look of black hood louver.
Need some opinions. I color matched the paint, then did a couple layers of gloss but it's nowhere near the Jeep. Leave as is or make it glossier?
Which hot did you use? There are wires everywhere. Not sure which one is constantly on without cutting them all and testing voltageYour install came out great, Scott! :thumb: Like Doug said, you'll find yourself using this compressor all the time so I'd wire it up so its hot all the time. I have a 30 gallon shop compressor that I can't remember the last time I turned it on. I use the one in the Jeep constantly its so convenient.
