Greetings
Stangler
Just a few more….
Stangler
1992 YJ Build Sheet
1992 Jeep Wrangler YJ Base 177,000 miles
2020-2021 Build
1991 Fox body Mustang GT Block, cleaned, machined, bored, honed 30 over
GT oem rods and miscellaneous parts from a 2nd donor ‘88 GT engine
Reman’d crankshaft
Camshaft .482/.482 lift, 214 duration @50%, 112 LSA
Comp cams high energy hardened std length push rods
New Ford 50oz harmonic balancer damper
Ford stainless steel hex head engine bolt kit - complete
Mr. Gasket hi flow 195 thermostat
Novak custom YJ/SBF engine mounts
Novak transmission mount
Crane pedestal roller rockers 1.6 to 1
GT40 hi flo heads F3ZE-AA
61-65cc 1.84”/1.54” valves
3 way valve job
Trick flow springs, seals and caps
Polished tall aluminum valve covers, 302 performance
Dual plane Deepmoter performer aluminum intake
FiTech Go Street EFI Master kit 400hp
ProComp HEI distributor with coil
Chrome Ford Performance breather/filter
4 row aluminum radiator with electric fan
New Tuff Stuff 100 amp polished chrome alternator
Billeted polished aluminum under-drive serpentine pulley system
New CarQuest premium reverse flow water pump
New FX HD Cast clutch flywheel
Stage 2 Banhauf clutch rated at 400+ hp
Novak Adapers clutch slave cylinder
T18 Ford 4 speed transmission rebuilt with granny 1st
Summit racing bell housing separator plate
Novak TC adapter and linkage T18 to NP231 transfer case
Slip Yoke Eliminator for original NP231 transfer case
Adams pinion yoke adapter for 8.8
New custom HD drive shafts F & R, by Adams
8.8 rear end rebuilt with new 4.10 ring and pinion with master rebuild kit
New brake cable adapter and E brake cable adapter for 8.8/YJ swap
Powertrax noslip rear locker (I already have a Lokka locker up front D30)
Rubicon Express 4” suspension lift, shocks, etc.
Custom 3/8 HD 1.5” lift boomerang shackles
Black 3” nerf bars
Kanati Mud Hawgs 35”x10.5”r15s
2.5” T304 Stainless dual exhaust with Jones Full Boar mufflers
Front and rear custom HD Adams driveshafts, 20% off code bleep20
