Help center console too change 4wd shifter linkage
Sharkey
Word Ninja
Did you remove ALL the bolts on the back of the console?
^^ This. I’ve only done this once and it sucked balls. If memory serves, the E-Brake really made it a PITA. Pretty sure you need to shift the transfer case and transmission for more clearance.
protospark
How do you fignal the plastic around the brake , if I take the dash face off will the give clearance or is there something I am missing all bolts lose I can lift it up gets stuck in brake , @#$@ any way no mater how you adjust , seats still in that should not make a difference brake how around the break ?
19YJ94
Not positive on that year, my 2011 manual, I actually had to push forward and flex the front of the center console and finesse the ebrake heighth at the same time. It wasn't fun at all.
Ddays
Mine is a 2014 so the console is different, but I've never attempted to take the console out without taking the seats out. It's not 100% necessary, but taking the seats out is easy enough that I'd do that as well. Gives you room to twist the thing around enough to figure out how it comes off.
hornet man
Not that it helps now but I cut an access so that I didn’t need to remove my console, would have been nice to have a factory access point.
albarb
I took it out once and it was a pain in the keister had to replace that wonderful plastic bushing a second time so I cut an access panel
JKbrick
The console in my 09 comes out pretty easy, can’t tell but it looks like your pics. Pull the ebrake up as hard as you can, then lift the console off from the back, leaving the front down. There are only 4 big screws holding the whole thing in. If yours is newer, carry on I don’t know what I’m talking about
