10-4, take her nice n easy. I'm thinking of buying a set of axles and wait till one snaps to replace them.
Lucky?? pffttt I'm screwed. LoL
Axle housings or axle shafts? If you mean axle housings, saving up for a set isn't a bad idea. If you mean shafts, being that you're running RCV's, you'll most likely break your R&P or the shaft deep inside the housing. I have seen it happen and neither are something you're gonna just swap out on the trail. Your rear shafts will most likely bend or break at the flange or, twist off at the splines. The first can just be fixed with a swap, the later will require a bit more work.
