notnalc68
That dude from Mississippi
How much was the quiet crawler? And where did you order from?
I found the best prices at Summit Racing
I bought all the parts separately from amazon to make up a complete kit.
Look in the link I posted to Dynomax website earlier in this thread, all the part numbers are in there.
Did you get the shorty or the longer muffler? I've been looking at doing a new exhaust.U cant go wrong with flowmaster amreican thunder! Love the sound its deeper than most systems which is wat made the choice easy for me... i just wish i had ran mine out past the axle
Im running the the flowmaster hp2 which is the same muffler in the amreican thunder system and i love it
I have the AFE Scorpion. I left the over axle piece off and just have a down turn off the muffler that exits near the rear wheel well. It is very very quiet. My tires are louder then it and thats not loud at all.
I got the 18"Did you get the shorty or the longer muffler? I've been looking at doing a new exhaust.
I just installed my quiet crawler two day ago, I love it so far. I ended up trimming 5" of the tail pipe at very end right before the tip. I am debating on trimming another 1".
I got the 18"
Nice install! Awesome rig too!
Mine's all done as well. Although the flattish muffler seemed to be sagging on the inner side at first. It would roll down the pipes no matter how tight I had the bolts. Had too keep watch and re-adjust it a few times. Now the pipes seem to be seizing and finally holding everything in place.
Did u run into this as well? I may have the pieces welded should it keep rolling down.
Oh and it sounds REALLY good!
I did run into this. There was no relief cuts on the muffler I received. I had the whole thing in and was tightening the clamps when I noticed this. I ended up stripping one clamp. I took the whole thing out and cut the relief notches in the muffler. Holds good now.
That's it! Just checked and ur right. No relief cuts. Guess I've got some more work to do. [emoji35]
VeruGE, what'd you use to make the cuts?
Thanks for the help!
Those are my pics, yes I did make the cuts. I used a grinder with cut off wheel wheel.
