Got some used rk arms from ddays today, thanks again
Ha. NiceHow much for the used oil? I need some for my frame
:cheesy: no he isn't
When you get mad trying to get the bent control arm out, you bend it even worse in the other direction and also sideways somehow.
What would be the proper way? [emoji848]
Gave up since even slid all the way against the axle I'm still 1" away from getting the arm in the front mount.
Oh fuck Jim - those rears are the dumbass "mid-arm" versions of the CA's. They are one inch longer. Man I apologize - I should have remembered to tell you that.
But being that they are hollow do you think you could cut an inch off of them or will doing so not give you enough threads to hold the ends properly?
Finally got the new stock arm in.....
Took pulling the coilover, pulling out the driver side arm frame bolt, letting the axle droop super low, then pulling it with a ratchet strap till it finally moved back. Somehow it was stuck in one spot before.
