Tcdawg
JK's JK said:Can someone please tell me why the sensor needs to be out when installed? I cant figure it out.
The sensor needs to be extended out while the carrier is put back in the diff because it has to be on the outside if the dog clutch...after you get the carrier installed, the sensor will go back in to its normal location. You can use a little piece if toothpick to keep it extended during install.
