This isn't going to keep you from going on the trip, is it?
Might be dumb but did you check the bolts of everything else? Did you touch any of the brakes? I hope you figure this out man.
Have you tired disconnecting the front ds and seeing if the noise is still there?
Update,
I removed my front driveshaft during lunch and the noise/vibration is gone. With that being said, what can in do to correct this issue?
I am current at 3.5 caster, and close to 3" of lift and still had vibration with the front driveshaft installed. I would like to get back to 4 caster for better on road handling again and 3.5 of lift. Shouldn't that be possible without any vibrations and noise with a 4.10 ratio, 1350 coast DS, and a factory D44 front axle? I know you need the pinion yoke and DS to be as straight as possible with each when running a CV style DS, but I hear others are running this type of setup with zero issues and higher lift. Could I have a bad DS from coast?
Update,
It was sent with a yoke for the axle and transfer case.You say you have a coast 1350, did you get it with a replacement yoke or with flange adapter? If you have the later, I ran that setup and had nothing but problems when it comes to vibrations.
Okay, if you got replacement yokes and still have vibration, your best bet is to try and get your caster back down to a solid +4°. If you still have vibrations, I would try getting the shaft rebalanced even if all looks good.
