I couldn't stay jeepless
jdofmemi
I like the black grill, and the other black you are adding.
It does a good job of breaking up the yellow.
Get the ratio of yellow to black right and it will look great.
Can't wait to see it done
I prefer the color matched grill more than black myself. Especially with bright colored Jeeps.
Bierpower
Nothing major but still tinkering. Made one of the holes for the Evo corner tail light.
Got some goodies from hinrichs today.
Truck-lites and a spiderweb shade
Tomorrow the nut-sert crimper should be in so I can get these corners done.
Bierpower
Got a jump on things today. Started off with swapping out the input shaft on the transfer case.
Once that was back together I mounted the shifter brackets and put the new tail housing on the transmission.
Then I wheeled the engine stand out of the corner and put the new engine mount plates on.
From there I did a lot of shuffling things around. With limited garage space, the 3.8 has been sitting in the jeep so I pulled that out and set it on the floor and mounted the new engine brackets on the Jeep side. I pulled the LS off the stand and torqued the flexplate back on, then set that on the floor. Next I got the transmission on the floor and bolted it back up to the engine. Laid out the new wiring harness on the engine and pulled a bunch of unneeded wiring out of the Jeep. To finish off the night I ran down to the parts store and picked up a couple sensors and seals for tomorrow.
Good luck, man. Your story narrative is giving me flashbacks. Your project is far more involved though. :beer:
Bierpower
Good luck, man. Your story narrative is giving me flashbacks. Your project is far more involved though. [emoji481]
It's a little interesting not having any instructions but most of the stuff is well labeled or obvious. Some things, as Robbie said to me, you just have to use your brain. Glad your up and running again.
Bierpower
Since this morning I did a lot of adjusting. Most of the day was spent on small details like mounting all of the accessories and running a whole lot of wires all over the place.
It's finally starting to look like a real Jeep. With the engine in and all the accessories bolted on I was able to get the grill bolted on the Jeep for the first time since I bought it.
Got the transfer case hung and all of the transmission mounts installed.
I finally took the time to get the first corner put on. I'm going to try and get the other side done tomorrow.
