I guess it's the "Super Stocker" build
JKbrick
Good to know! I misunderstood. I’ll work on that when the tie rod arrives. I was viewing from the driver’s side. Driveway reads zero at both front tires pulled up right to the garage door, but the rear is 3° different. The driveway has a break about mid-way for drainage. Should I factor a change in for the rear being slightly lower or is the zero reading at the front wheels adequate?
Can you block the front wheels and put a jack under the rear diff to pick it up to level?
USMC Wrangler
That’s definitely a thought I’ve had. I have a huge driveway but only a small portion is concrete. I need to check the concrete angle if I park perpendicular to the garage. Or, I just need to throw everything away inside my garage.
USMC Wrangler
Just park on the angle and do math. [emoji41]
So it shows 0° at the front tires on the ground but 3-3.5° at the rear tires. When I installed my adj FLCA’s I was in a rental house. The concrete driveway was perfect at 0°. Now the house we bought has the break/slope.
I guess if I make my wife and kids get all their crap out of the garage (ok, I have some too) I’d probably be better off in many ways.
BaddestCross
So you're saying there's not enough to get both axles on the angle part of your concrete?
USMC Wrangler
My Exodus Jeeps tie rod arrived yesterday and I got it installed this morning. A co-worker loaned me the proper reamer for GM 1 ton TRE’s, which was a nice little savings.
Here are some comparison shots.
Got some swag too!
After test fitting I only had to ream the pass side. The drivers side looked great. I literally took the slightest bit out of the pass side and it pulled all the way in at 60 ft lbs.
I called Bubba to check on torque specs and he gave me a length to start at as well. I believe it was 58 3/8” and measuring at the tires got me back to about 1/8” toe from 5/8” with my bent factory TR. I did have to re-center my steering wheel. I guess that’s from me adjusting as I bent things and the toe got out of whack.
It drives great now on the highway and even on the rough, uneven, chipped sealed road near my house.
Highway
https://youtu.be/Kp-Wv_1tAeg
Chip sealed road
https://youtu.be/bPqXfRXkksQ
In the last video you can see me let go of the steering wheel going through a low water crossing (currently dry) that used to throw my steering into fits.
Great product and great service as usual!
I added the non-model specific Jeep decal to my tailgate collection. I’m not even complaining it’s not for a TJ or a JK or a JL! [emoji38]
As for my camber...I ran out of time before shift to address it. But I did confirm if I pull up perpendicular to my garage it should give me a good reading to start with, at a level angle. I’m hoping to address that tomorrow or Saturday.
Sunday is the big gear swap day! I’m pretty excited about the whole process and the intended result!
jesse3638
If you have an 8' level you can put under the jeep it'll get you close to what you're dealing with. I have a digital angle finder I can 0 out. I put a level under the jeep 0 it out and then measure my caster. No math needed...haha. Also it's best to measure your caster from the pinion flange or yoke. If you have a yoke you can unbolt the front DS and Bolt a piece of flat stock the the yoke so you have a flat surface to measure off of.
USMC Wrangler
If you have an 8' level you can put under the jeep it'll get you close to what you're dealing with. I have a digital angle finder I can 0 out. I put a level under the jeep 0 it out and then measure my caster. No mate needed...haha. Also it's best to measure your caster from the pinion flange or yoke.
Thanks! Tomorrow when my gears get swapped I’ll check it since the front DS will be removed. Also the shop we are using has a large section that’s supposedly at 0°.
There will be three of us working on it. Setting up gears is not in my wheelhouse so I’ll be breaking down each axle and playing gopher as needed while the other two work the gears. I’ll check the caster before reinstalling the front DS.
USMC Wrangler
Parts, fluids and tools are loaded. Links to Project-JK torque settings and related write ups are saved in my notes for quick reference.
I feel like a kid on Christmas and not sure if I’ll sleep tonight much. By this time tomorrow I hope to be doing break-in runs on the new gears!
Thanks to everyone who have answered my dumb questions and Bubba for getting me setup with parts. [emoji1303]
