Mike Pierson
Damn! Very nice!
Damn, that is looking sweet!Think we have some decent travel now. And yes, those bumps are set to full bump
Guess it’s a low rider now.
Checking things to trim up before sending off to powder coat.
So what’s the plan to power this piece of bad assery inquiring minds want to knowGuess it’s a low rider now.
On the home stretch now. Time for body work/inner panels.
John was working hard on @TheCaliforniaJeep’s 2dr getting his 5.13 gears, axle shafts, gussets and balljoints installed.
She thicccc!Guess it’s a low rider now.
While I’m sure it will actually end up with loads of travel you could definitely a pull off a lower center of gravity build like the Jeep Lower 40 concept or Vengeance the stretched 2 door.Guess it’s a low rider now.
I will keep it as low as possible for sure.While I’m sure it will actually end up with loads of travel you could definitely a pull off a lower center of gravity build like the Jeep Lower 40 concept or Vengeance the stretched 2 door.
This thing gets more and more badass!!!
Size doesn’t matterYou still gonna wheel with us little Jeeps?
oh yeah. Already a couple trails that I know will be a pain lolShe thicccc!
Thank you sir. Really excited to see all of the final touches come togetherLove how this build is coming![]()
More cylinders of courseSo what’s the plan to power this piece of bad assery inquiring minds want to know![]()
Thank you buddyLooks amazing, coming together nicely.
You been talkin to my wife?Size doesn’t matter
35s do the job, 37s do it better.You been talkin to my wife?
How would you know?35s do the job, 37s do it better.
That’s what everyone keeps telling meHow would you know?
Size doesn’t matter
Let's face it, bigger is bigger, even if it's just by an inch...
Those wheels suck for moving around long term. I have that box and it’s good (mine has the doors not doors on bottom) but replace the wheels with the rubber air filled tires. The plastic ones suck when they get scuffed.We are always trying to stay organized and proficient. Instead of having to walk back and forth a million times from a Jeep and work bench doing gears, we finally put together a “gear cart” to have everything needed right at the axle. Also added organizers for shims for each specific axle. Couple more things to add but should really make things a lot smoother.
